Speedometer
Old Apr 21, 2006 | 12:17 PM
idgit0488's Avatar
idgit0488
Speedometer
I'm running 35s on my 79 F-150. Is there anyway to get the speedometer accurate. On my Jeep, you can just replace the speedometer gear in the T-case. Thanks for the help.
Old Apr 21, 2006 | 12:19 PM
rmalottwtes30's Avatar
rmalottwtes30
I did something similar I called a local shop that specializes in obsolete ford parts. They asked me my gear ratio and tire size and they hooked me up with the right one.
ford390gashog's Avatar
ford390gashog
the same applies to the fords. just replace the plastic drive gear with the correct one and you are set.
Old Apr 21, 2006 | 12:39 PM
unrulee's Avatar
unrulee
Jeff's Bronco Graveyard has quite a few different ones to choose from.
Old Apr 21, 2006 | 12:59 PM
idgit0488's Avatar
idgit0488
Thanks for the quick replies! Does anyone know if there is a chart that shows how many teeth the gear needs to have? I'm running 35s with 4:11 gears.
Old Apr 21, 2006 | 08:40 PM
fatherdoug's Avatar
fatherdoug
National Parts Depot(A sponsor) has the calculation in their website catalog under the driveshaft, speedometer, axle category.
Old Apr 21, 2006 | 09:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
idgit0488 -Please use the default font size to make your posts easier to read.
Old Apr 21, 2006 | 10:21 PM
Mil1ion's Avatar
Mil1ion
Yes there is.
http://www.tciauto.com/tech_info/speedo_gears.htm
http://www.transmissioncenter.net/sp...___va.htm#ford
Idgit,
There are some people on FTE that can't read small text.
These people are IN the Know of many things.
These people would like users to make sure the font is readable........ that is if the poster wants their questions answered.
