is there a 347 stroker kit for it?
Old Apr 20, 2006 | 10:46 PM
Fordever2's Avatar
Fordever2
i was just wondering if there is a stroker kit for a 1996 f150 5.0 i wanna make her be as powerful as she is beautiful
Old Apr 20, 2006 | 11:47 PM
06fx4's Avatar
06fx4
yes...its the same as the 302 from 1970 minus the roller cam and is the same as the mustang.BUT you may run into computer problems meaning you may need to get a new computer made for the biggar cubes. And definatly some form of more fuel weather injectors,fuel pump, something.
Old Apr 20, 2006 | 11:57 PM
Fordever2's Avatar
Fordever2
thanks pal
Old Apr 21, 2006 | 09:48 AM
Kemicalburns's Avatar
Kemicalburns
the computer will be fine kinda. a custom tuned chip or dyno time will for sure be required. larger maf , 24-36lb injectors etc.. your exhaust will need redone, and so on. fun project. is this 2wd or 4wd? and what are you wanting to do with this truck? a bolt on vortech supercharger or kennebelle supercharger might be a more cost effective way to go in your situation. plus its bolt on, and will give you a larger gain with better hi way manners
Old Apr 21, 2006 | 06:29 PM
Fordever2's Avatar
Fordever2
the truck is gunna be a 2wheel drive street truck but im gunna be driving it quite a bit and its already going to need a rebuild. so i figured a cam and some other stuff so i figured the stroker might be cool
Old Apr 22, 2006 | 01:06 AM
06fx4's Avatar
06fx4
i dont know how much money you have toward a rebuild but if it was me id throw on some afr heads a cam, not too big keep good vacuume. and a set of intake manifolds, and headers. you should be almost 400 hp and you can always do a maf throttle body and what not after the engine is installed because its not any harder with the engine in.And as long as you keep the rpms down the bottom end should hold up. if you have anymore quetions post them ill be more than happy to answer anything, i love doing this stuff
