"1977 F-150 help"
Old Apr 20, 2006 | 10:06 PM
inline6 Red Neck's Avatar
inline6 Red Neck
Red face "1977 F-150 help"
i just bought a 1977 f150 yesterday and i noticed on the way home i did never have any oil pressure and the coolant temp didnt work what are some thing i can do to fix or check to see whats the problem
Old Apr 20, 2006 | 10:13 PM
eedvark's Avatar
eedvark
First step should be to look under the hood and see if the senders are hooked up.The sending unit wires might not be hooked up.Second check to see if the dash end is hooked up to the instrunent panel.Then take it from there.
Old Apr 20, 2006 | 10:18 PM
Bdox's Avatar
Bdox
Since both gauges are not working it is most likely that they are not getting power from the small voltage regulator on the back of the dash. Bad connection, printed circuit or bad regualtor.
Old Apr 20, 2006 | 10:58 PM
Mil1ion's Avatar
Mil1ion
Before pulling the cluster out
You have 2 options.
1) Remove the wires to the sending units one at a time and ground the wire connector to the engine intake.
Turn the key to on ......... Does the gauge peg to the right ?
If No, the problem is with either the gauge or the circuitry.
If it does, the problem is the Sending unit.
2) Remove the connection from the sending units one at a time and test each wire
for a pulsing 5 volts with a test light or an sweep Multi-meter.
If no power, the problem is either the ICVR or a broken wire.
Old Apr 20, 2006 | 11:24 PM
Bdox's Avatar
Bdox
Better answer. Thanks Mil.
ICVR= instrument cluster voltage regulator
Old Apr 20, 2006 | 11:31 PM
wintremute's Avatar
wintremute
The instrument cluster printed circuit is probably coroded. Here's what I did and it works well... Clean (rub rub rub a dub and then rub some more)all of the contacts to the printed circuit with a pencil eraser, then wipe with a WD40 soaked rag. That fixed most of my probs other than some bad grounds here and there.
I learned a long time ago in the computer repair business that a pencil is your friend. you get a good high grit abraisive and graphite lube in one convenient package.
Old Apr 21, 2006 | 10:33 AM
Mil1ion's Avatar
Mil1ion
Electrical cleaner spray or methyl hydrate works well too
