Totaly Stumped
Old Apr 20, 2006 | 09:32 PM
psdiesels rule's Avatar
psdiesels rule
Unhappy Totaly Stumped
I have a 2001 F350 7.3 psd just replaced cps,icps,and ipr valve engine still dies and i keep getting code 1211 any ideas would be apreciated thanks
Old Apr 20, 2006 | 09:43 PM
DavidT.'s Avatar
DavidT.
I'm sure you've done the basics but this is what Mitchell On Demand states as some possible causes of the P1211 code:
Low Reservior Oil Level
Poor Oil Quality
Injector "O" Ring leak
Faulty IPR valve (Looks like you've already replaced that)
Faulty Oil Pressure Pump
Faulty PCM
Sorry couldn't help you out more.
Old Apr 20, 2006 | 09:46 PM
zx250's Avatar
zx250
Of the next Riffraff East
What mods does your truck have?
Old Apr 20, 2006 | 10:02 PM
psdiesels rule
No mods yet
Old Apr 20, 2006 | 10:05 PM
zx250's Avatar
zx250
Why did you replace all of the other items? Were you having problems/codes before?
Old Apr 21, 2006 | 05:54 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome psdiesels rule to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 21, 2006 | 06:56 AM
ryaneverk2's Avatar
ryaneverk2
P1211 = ICP pressure above/below desired : IPR valve failed, stuck, or shorted to ground
But... you said you already replaced the IPR valve.
What level is your oil at in your crank case? Give the dipstick a check.
Old Apr 21, 2006 | 07:36 AM
Kwikkordead's Avatar
Kwikkordead
Yeah, and change the oil if you haven't done so recently. There has been documented cases here on FTE where an oil change cured the problem.
If that doesn't do the trick, given what you've replaced already, I would be thinking worn out HPOP.
Old Apr 30, 2006 | 11:02 PM
psdiesels rule
Thank's for all the help turned out the nut that holds the sensor on the shaft was striped so sensor was ratteling on shaft replaced nut torqued it down runs great now.
Old Apr 30, 2006 | 11:13 PM
zx250's Avatar
zx250
Glad you found your problem and letting us know. Might save others some expensive trial and error repairs when a loose nut is all it is.
Welcome to FTE...
Old Apr 30, 2006 | 11:33 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Which sensor was that?
Old Apr 30, 2006 | 11:55 PM
zx250's Avatar
zx250
Guess I should have ask that to. I thought it was the ICP sensor, but looking back I'm not sure about being mounted on the "shaft".
Maybe psdiesels rule will jump in and help us.
Old May 1, 2006 | 03:46 AM
ryaneverk2's Avatar
ryaneverk2
Yes, please share with us exactly which sensor it was... good to know for future reference.
Old May 1, 2006 | 06:26 AM
lancer's Avatar
lancer
The ipr is on the back side of your hpop. If you look down the back it is to the drivers side of the truck. It has an elctro magnet (i think) mounted over a shaft which houses the gut of the ipr. It is held on with a tin nut. I have changed mine to so tahts how i know this. Hope this helps
Old May 1, 2006 | 07:56 AM
Kwikkordead
I've looked down there before on my '99 for the tin nut and saw a plug instead. I'll have to look again today. It's on the end of the IPR?
