Modular V10 (6.8l)
Ebay headers???
Old Apr 20, 2006 | 08:28 PM
Bracen's Avatar
Bracen
Ebay headers???
I was just browsing through Ebay when I came across these headers;
http://cgi.ebay.com/ebaymotors/99-04...QQcmdZViewItem
Now honestly, I almost bought a set right then and there. I kinda figured that I'd start with the headers and Y-pipe and go from there. But $$170$$ for stainless headers? Seems cheep, maybe too cheep.....lol... Anyone have any thoughts????
Old Apr 20, 2006 | 08:55 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The one you linked to doesn't seem to have an EGR port.
There is currently a set of Gibsons at $199. These particular ones DO have the EGR pipe bung.
If it's the same seller as last time, their zip code matches Gibson's...
Others here have used them, no problems, they fit, etc. Me? I'd probably get them ceramic coated after making absolutely sure they have no leaks.
However, most people have reported they don't do much, and that the Y-pipe does more.
Let others speak on this more
Old Apr 22, 2006 | 12:19 AM
jake00's Avatar
jake00
ya get what ya pay for.....
search this forum, I dont think anyone will recommend headers in terms of a good value
Old Apr 22, 2006 | 10:20 AM
boxcar1974's Avatar
boxcar1974
I agree with jake, I have Banks headers and could have lived without them. The worst part of stainless headers is how thin they are. You can hear the exhaust pulses all the time. Sounds like pfft just like a leak.
Old Apr 22, 2006 | 02:31 PM
mdpopo59's Avatar
mdpopo59
I bought the Ebay headers this winter and had them installed. I had 6 of those stock header bolts broken off that I had to fix anyway, so I figured what the heck. They were a tight fit but they worked. I was suprised at how constricted the stock manifold is. When you look down on it from the top of the engine you can't see the pancaked cross section.
I didn't need the EGR fitting for my '01. I have ordered a new set of better quality header gaskets from Mr. Gasket because the cheap ones they sent never sealed right.
The engine/exhaust noise is louder from the engine compartment. I assume thats because you can hear the exhaust exiting the valves through the thinner walls of the header pipes. The cast iron manifolds were a lot quieter.
My mileage didn't change any and there was no improvement at lower rpm's, but towing it seems to like the higher rpm's. It really purrs around 3,500.
Oh, and they look cool. You can see them from outside the front fenders above the tire, through that little gap between the frame and the fenderwell.
Old Apr 23, 2006 | 11:42 PM
Bracen's Avatar
Bracen
Thanks for the info guys!
