Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Frame Swap Update
Old Apr 20, 2006 | 08:26 PM
51dueller's Avatar
51dueller
Frame Swap Update
For you guys that don't browse the 48-60 forum, I've provided a link to my Frame Swap Update.
https://www.ford-trucks.com/forums/s...24#post3614324
Old Apr 20, 2006 | 10:06 PM
preppypyro's Avatar
preppypyro
Extremly cool man, you really work fast! You took a whole truck apart in no time!
Old Apr 21, 2006 | 12:24 AM
Fomoko1's Avatar
Fomoko1
Really, really fast. I am not letting you near my gravel trucks, they would be in many pieces in short order.
Old Apr 21, 2006 | 08:51 AM
51dueller's Avatar
51dueller
With a part time job you have some free time.
Monday: I had the box removed and rear gas tank.
Tuesday: I removed the front sheetmetal and unbolted the cab.
Wednesday night: removed cab.
Thursday: removed engineand tranny, scraped gunk off, removed crossmembers, swapped rearaxles and added crossmembers.
I've only needed help to lift the front sheetmetal off (one piece) and the cab, the rest I've done myself. I'm a one man dismantling crew! Also I've waited a month to do this so I have pretty much everything planned out.
Old Apr 21, 2006 | 04:32 PM
preppypyro's Avatar
preppypyro
Thats cool man, I wish I had tht kind of spare time, Im jealous!
Old Apr 21, 2006 | 09:24 PM
lockups's Avatar
lockups
When you narrow the frame and shorten the cross members what do you use to re-attach them? On my old truck There were rivets, and for now I only have bolts in the holes, Do you weld them solid or use heavy duty bolts? I'm trying to figure out how to reattach them.
Old Apr 21, 2006 | 10:31 PM
Fomoko1's Avatar
Fomoko1
Welds may cause cracks, bolts would be preferable as there is some give with them. Welds don`t flex like bolts and something will have to give when the frame flexes.
Old Apr 21, 2006 | 10:44 PM
preppypyro's Avatar
preppypyro
I always got told bolts too, get the good grade ones and ya should be good.
Old Apr 22, 2006 | 09:11 AM
51dueller's Avatar
51dueller
I'm using grade 8 bolts and I'm only going to narrow the crossmembers that aren't the main load carrying. The load bearing ones I'm replacing with crossmembers from the '51 frame as the are the same design and correct width. This way I won't have to worry about cracking welds if I toss an engine block in the box.
Old Apr 23, 2006 | 09:33 AM
preppypyro's Avatar
preppypyro
Thats cool, sounds like it will be a pretty tough truck.
Old Apr 23, 2006 | 01:57 PM
51dueller's Avatar
51dueller
I plan on building a truck unlike Fomoko's sissy '56 with the car suspension.
Old Apr 23, 2006 | 10:29 PM
preppypyro's Avatar
preppypyro
Lol Sounds cool for sure
Old Apr 24, 2006 | 10:08 AM
Fomoko1's Avatar
Fomoko1
To put it another way, a Louisville 8000 10,000 pound rated front axle vs a feather weight F250......
Old Apr 24, 2006 | 11:06 AM
Snowking's Avatar
Snowking
I wonder if there is a way of putting a Ford truck body on a old Hough payloader?
That'll shut everyone up.
Old Apr 24, 2006 | 11:11 AM
ferrousFord's Avatar
ferrousFord
Fomoko you have all the bases covered! Different trucks for different purposes( and all of them fords) -life is good!
