E40D shifts funny
Old Apr 20, 2006 | 05:55 PM
factoryphil's Avatar
factoryphil
E40D shifts funny
I have a 92 f150 4wd with e4od and when I put it into gear it takes a couple of seconds to move. The fluid level is good and has new rear end and u joints. I get vibration when I slow down for stops and It shifts into 3rd rough when I get on the gas when the trans is warm. any ideas
Old Apr 20, 2006 | 07:02 PM
quicklook2's Avatar
quicklook2
change fluid, drain convertor, and put in new filter.
Old Apr 20, 2006 | 08:47 PM
water 5's Avatar
water 5
was there a vibration be for the u-joints is that why you replaced them?
Old Apr 20, 2006 | 09:46 PM
handyman43358's Avatar
handyman43358
I agree with quicklook. If this doesn't do the trick, prepare to rebuild it in about 20,000 miles or so. When I bought mine, it took it a minute to engage in gear. Then all of a sudden, she died.
Old Apr 23, 2006 | 11:10 AM
Rockford44's Avatar
Rockford44
funny tranny
I have a 92 F-150 2-wd and I have about the same symptoms as you do. It has about 150,000 kms.
Old Apr 23, 2006 | 11:11 AM
Rockford44's Avatar
Rockford44
one time it shifts very hard and the next you can hardly feel it shift.
Old Apr 23, 2006 | 11:22 AM
quicklook2's Avatar
quicklook2
same answer as i gave earlier.
i also use lucas trans treatment.
Old Apr 23, 2006 | 05:26 PM
handyman43358
Hard shifting is most likely an electrical problem. Mostly caused by irratic signals from the VSS (Vehicle speed sensor) or the PSOM (Programmable Speedometer/Odometer Module.) The computer picks up information from both of those sensors, and many others, to determine shift points and line pressure. Increased line pressure will increase the firmness of a shift, and vice versa.
So basically, if the computer loses information from any sensors thats help control the transmission, the transmission will go into "Fail Safe" mode, to prevent wear on the transmission. Believe it or not, those "hard shifts" may feel like it's going to break things inside, but it's actually saving the transmission from wearing much quicker.
My advice is to pull the codes. Generally, if this hard shifting occurs, your OD Off light will blink, indicating a problem. The first step is to pull the codes, even if you don't have a check engine light.
