Chemical Reactor
Old Apr 20, 2006 | 12:55 PM
gseeders's Avatar
gseeders
Chemical Reactor
SAW THIS ON THE INTERNET.
PORTLAND, Ore. - A tiny chemical reactor that can convert vegetable oil directly into biodiesel could help farmers turn some of their crops into homegrown fuel to operate agricultural equipment instead of relying on costly imported oil.
"This is all about producing energy in such a way that it liberates people," said Goran Jovanovic, a chemical engineering professor at Oregon State University who developed the microreactor.
The device — about the size of a credit card — pumps vegetable oil and alcohol through tiny parallel channels, each smaller than a human hair, to convert the oil into biodiesel almost instantly.
By comparison, it takes more than a day to produce biodiesel witih current technology.
Conventional production involves dissolving a catalyst, such as sodium hydroxide, in alcohol, then stirring it into vegetable oil in large vats for about two hours. The mixture then has to sit for 12 to 24 hours while a slow chemical reaction forms biodiesel along with glycerin, a byproduct.
The glycerin is separated and can be used to make other products, such as soaps, but it still contains the chemical catalyst, which must be neutralized and removed using hydrochloric acid, a long and costly process.
gseeders
Old Apr 20, 2006 | 02:47 PM
Kwikkordead's Avatar
Kwikkordead
Got a link?
Old Apr 20, 2006 | 03:46 PM
misterfisher's Avatar
misterfisher
Cool
I second that!
gseeders
Old Apr 20, 2006 | 04:00 PM
gseeders's Avatar
gseeders
http://hosted.ap.org/dynamic/stories...MPLATE=DEFAULT
hope this works. If not you will be able to fine it on the associated press, type in the search field "bio diesel"
gseeders
Old Apr 20, 2006 | 04:04 PM
zx250's Avatar
zx250
Of the next Riffraff East
Did a quick search and got this. http://oregonstate.edu/dept/ncs/news...roreactors.htm
