1997 5.4 engine code
Old Apr 19, 2006 | 05:01 PM
97F250LD4X's Avatar
97F250LD4X
I noticed about 3 weeks ago that my check engine light was on. I took it to Pep Boys and they said there was no code and so they cleared it. A week later The check engine light came back on and I went to Autozone. They plugged in thier scanner and got a code PO171. What does this indicate,what causes it and how can it be fixed? The truck does not run any different than it has in the past. In fact I havent noticed it running different at anytime,whether the check engine light is on or not.
Old Apr 19, 2006 | 10:26 PM
Dave23bme's Avatar
Dave23bme
This link should answer your question
PHP Code:
http://www.obd-codes.com/trouble_codes/generic/p0171-system-too-lean-bank-1-oxygen-sensor.php
Old Apr 20, 2006 | 02:47 PM
LxMan1's Avatar
LxMan1
It is showing a lean condition on bank 1 (passengerside). This is usually caused by either a dirty MAF or a bad PCV hose elbow at the rear of the intake manifold.
Old May 1, 2006 | 01:12 PM
2000Ford2000's Avatar
2000Ford2000
I cleared my 0171 with a couple of cans of STP gas treatment and very little gas in the tank. It initially showed 2 codes of both banks lean, then I cleared the codes, put the STP in, and later I got just 0171 come back on. Cleared that one and it hasn't come back on in a year (40,000 miles).
Old May 8, 2006 | 04:31 PM
exptrlrdr01's Avatar
exptrlrdr01
Unhappy engine code P1132
I have a 2001 expedition 5.4L 4X4. My check engine light came on with the code P1132 and has started running funny. When I start the truck and drive it will hesitate and spit and sputter and all of a sudden it stops and surges forward. I was told it was a bad fuel cap and I replaced it and still have the problem. A couple of months ago I would hear a humming sound at the rear of the truck after I turned it off. I decided to open the fuel cap and when I did the humming stopped. It was running fine back then. Then the humming stopped and truck now runs bad. Anyone have an idea?
Old May 8, 2006 | 08:56 PM
Dave23bme's Avatar
Dave23bme
P1132 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
i do not know what that means, but at least it could help you start.
Old May 8, 2006 | 10:01 PM
LxMan1's Avatar
LxMan1
It is showing that either the passenger side front O2 sensor has failed of been unhooked.
Old May 8, 2006 | 10:35 PM
exptrlrdr01
Would that cause it to run rough and hesitate at acceleration?
