99 expy rear slide windows??
Old Apr 19, 2006 | 10:51 AM
99RedExpy's Avatar
99RedExpy
I have a little problem with my rear windows that slide side to side, they work fine but the have to be adjusted a little bit I think. The ends are pointing down and when I close them they wont close all the way because they are not straight. Does anybody know how how re-adjust these, I tried loosing the screw in the the little arm the opens and closes them but no luck. Let me know guys thanks.
Old Apr 19, 2006 | 11:40 AM
01silvergt's Avatar
01silvergt
Not 100% sure by what you mean "the ends point down", but if you are talking about the entire glass pointing down at the rear, then it sounds like a hinge issue. Not the pivot arm that opens them, but the hinges near the passenger doors. Look there and see if they are loose.
Old Apr 19, 2006 | 12:35 PM
99RedExpy's Avatar
99RedExpy
Yes the entire glass is pointing down at the rear, I will look into what you said thanks alot.
