Ping! Ping! Ping! you get the message, why?
Old Apr 19, 2006 | 09:47 AM
ricku's Avatar
ricku
89 f150 4x4 5.0 auto
Engine pinging under acceleration, do I need higher octane fuel, timing set, valve work....what?
Old Apr 19, 2006 | 10:03 AM
wassabe's Avatar
wassabe
My 88 F250 5.8L runs fine on any grade fuel. My 97 F250 5.8L work truck pings if I don't use mid grade fuel. I would try a higher octane and see if it helps.
Old Apr 19, 2006 | 10:07 AM
quicklook2's Avatar
quicklook2
more info is needed.
check wires, plugs, dist. cap, fuel condition, clogged exhaust.
Old Apr 19, 2006 | 01:33 PM
93f250-44cepeks-olf-olf's Avatar
clogged or simply restrictive exhaust....I never put the two together, but my truck has not pinged since I put the dual exhaust on it 3 years ago.
Ditto on the plugs, wires and cap & rotor. Check all the basic tune up stuff.
Old Apr 19, 2006 | 01:58 PM
andym's Avatar
andym
The EGR valve if clogged up and stuck in the open position can also cause pinging. Have you pulled your codes?
Old Apr 19, 2006 | 09:16 PM
ricku's Avatar
ricku
all plugs,wire cap,rotor, etc are relativly new.
exhaust from cat back is new, cat has been cleaned out.
no codes using the jumper wire.
Old Apr 19, 2006 | 09:28 PM
andym's Avatar
andym
Check your timing then. If it's right, then you are probably looking at carbon deposits on the valves.
