1978 - 1996 Big Bronco
Loose mounts?
Old Apr 19, 2006 | 08:19 AM
helirich's Avatar
helirich
Loose mounts?
I need to change my body mounts. They dry roted and cant be tightened. I removed one of the bolts and the mount wont come out. (its loose) It must be flanged to the frame, I Guess. Anybody done this before. Must I jack the frame apart four inches or what?
Old Apr 19, 2006 | 11:10 AM
buckeyebronco's Avatar
buckeyebronco
From what I understand (I have never done this before) you will have to raise the body of the vehicle a couple of inches to replace the bushings.
Old Apr 19, 2006 | 01:57 PM
helirich's Avatar
helirich
As best as I can figure the steel inner bushing is attached to the frame and the rubber is around it. I dont quite understand why its done this way. when you tighten the bolt, it's just steel body against the steel bushing. So I can rotate the rubber bushing loosely and the body can move maybe 3/4" with no dampening.
Old Apr 19, 2006 | 04:11 PM
johnarahill's Avatar
johnarahill
Just lift the body up a little bit and you should be able to knock it out.
Old Apr 20, 2006 | 08:23 AM
helirich's Avatar
helirich
I wil tackle it next week if I get the time.
