Like many others here, I have more than 1 old Ford truck. I also like no more keys on my ring than what is necessary, so for a couple bucks I made it so that I have only 1 key for 2 trucks, thus eliminating a key from my ring.
Is this a well know trick or a little known secret worth sharing?
1 key for 5 Fords? That sounds like what I need! When I was searching, I came across a post by you indicating that you know quite a bit about these locks. I'm guessing your's are re-keyed?
I cheated a bit on mine. I had a new key cut with one side for one truck and the other side for the other truck. I put a small v-notch in the head to know how to use it for each truck - notch down for one, notch up for the other.
I have pins etc to re-key them. I keep spare cylinders around and re-key them when my brother-in-law or I find them in the yards or at the supply house. The real new fords I can't do anything with but I have replaced cylinders in everything 78-94. I save the old cylinders for replacement when I sell a vehicle. The 90's cylinders are real junk. My BIL is a locksmith and has a number of "double sided" keys for his fleet.
A friend of mine happened one day to find out that his Mother's 82 Mustang key fit his 68 Mustang perfectly.
It isn't a secret that there are numerous duplicate keys out there,.
In fact, several times on here I have suggested that when one locks themselves out of their truck, that they round up as many Ford keys as possible and try them because one of them might just work.
That's cool. I used to work at a hardware store and had to "master key and key alike" entry and dead bolt sets for a few property management companies. I had 3 master keys that could get me into over 4,000 apartments. I've never messed with car keys. House keys are easy, though. I used to screw with my friends and tell them "hand me your house key, count to 3, and I'll hand it back. It's so easy to memorize the pin depths (only 5) and cut one from a blank using these memorized depths without even having the original. I would give them their "new" key and they were shocked that all it took was seeing their key for 3 seconds and I could then go make one. Ok... enough OT...
No such luck here, all of my keys are cut totaly different, so I had to make my special key to work both trucks.
Some of the older fords keys were so close that they work in other fords. My 79 F150 key worked in my dads 70 econoline. It took a little bit of wiggling, but it worked.
