1978 - 1996 Big Bronco
88 Efi 351w Timing
Old Apr 18, 2006 | 01:58 PM
johnarahill's Avatar
johnarahill
88 Efi 351w Timing
I have my timing set at the factory recommended 10 degrees, I'd like to set it to 12. However, I know that when the SPOUT connector is hooked up, the computer takes over anyhow. Is there a way around this?
Old Apr 18, 2006 | 02:16 PM
Kemicalburns's Avatar
Kemicalburns
unhook the spout connector, set the timing to 12* then reconnect the spout with motor off and start back up. Done! unhooking the spout is similar to unhooking the vacum advance on older carbed setups.
Old Apr 18, 2006 | 03:29 PM
johnarahill
Thanks, I've heard this can improve performance and fuel economy, I guess we'll see. . . or maybe we won't see.
Old Apr 18, 2006 | 05:01 PM
Kemicalburns
it will help some. to really get the best results , install an msd coil, and new plugs gapped to .55 with some new plug wires as well.
