Offroad & 4x4
Diesel Muddin
Old Apr 17, 2006 | 10:07 PM
threefiftyone's Avatar
threefiftyone
Diesel Muddin
Any tips I should know about mud runnin in a Diesel? I know you need wheelspin and momentum. But does the torque from a diesel make up for the high rpm's needed for a gas engine? I went yesterday, and kept it about 2500 rpm's, and seemed to have plenty of wheelspin.
Old Apr 17, 2006 | 10:12 PM
my79f's Avatar
my79f
im not sure if it was just my truck or theres others like it but mud likes to come through the steering shaft boot on the firewall so dont put in items you dont want wet down there. also make sure you are in four wheel drive before attempting mud, and one last thing wash the engine off the day you go but dont wash it when it is still hot.
Old Apr 17, 2006 | 10:43 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
mud running with a diesel sucks...because there is so much wieght up front when compared to a similar powered gas rig
Old Apr 17, 2006 | 11:55 PM
mustange70's Avatar
mustange70
Ditto on what KO said, but the one advantage to diseals is that you can get away with running a faster gear set cause the low rpm power band makes up for the power loss, and thus a high wheel speed can be achieved.
Old Apr 18, 2006 | 09:58 AM
Customz's Avatar
Customz
That thing is like a boat anchor up there...any small hole a gasser would cruise right over a diesel may sink. Good power though, especially with a tuner. I can't go in as deep of mud, but I am not lifted. It can also be difficult to recover a stuck diesel (with the exception of a few here) they are usually the biggest trucks out there and samuris and wranglers don't pull too well.
Edit: see Pro's chevy recovery video...AWESOME
Old Apr 18, 2006 | 11:07 AM
RawPower's Avatar
RawPower
I wouldnt say it sucks... but you do run into more problems. I enjoy it though, just another challenge. Yes, you will sink like a rock.
Old Apr 18, 2006 | 12:22 PM
KubotaOrange76
i loved my diesel as well, but unless you bomb it pretty serious the extra weight is a burden
mine was borderline with 350 rwhp and over 700 tq
Old Apr 18, 2006 | 12:27 PM
RawPower's Avatar
RawPower
If you want to even compete with some BB's then you will have to run some ginormously wide tires that dont dig too quick but also pull well and lock both ends.
thats a lot of ft-lbs KO...
Old Apr 19, 2006 | 09:41 PM
threefiftyone
Right now, I'm stock. Just a K&N, 4" Exhaust, and 265 mud radials. Oh yeah, with 4.11's. Wish I had 3.73's most of the time, 'till I need to pull stumps! When I was wheeling at my buddies' house last weekend, I remembered that if you slightly push on the brake (while you're spinning) the LS will engage both wheels. And it worked!
Oh, and when you go wheeling in granite mud, make sure you wash off that day. I usually let it sit for a week, to show off the battle scars, but that granite sets like concrete.
Old Apr 19, 2006 | 11:24 PM
Customz's Avatar
Customz
I think 400 hp and 800 tq at the rear wheels will be obtainable on a 6.0. Especially if it ain't a daily driver anymore. I'm planning on 7 inches of lift and 37-40 inch tires with 5.13s and ARB f/r. Maybe I should go as low as possible with the 5.38s. Works out to be a 5% rpm difference, but with a truck that big it could use all the mechanical advantage available. 2006 XL F250 CC LB 4x4. Most importantly its gotta be able to tow...
Old Apr 20, 2006 | 12:46 AM
fishmanndotcom's Avatar
fishmanndotcom
make DARN sure you have a good air filter and its up out of harms way! diesels suck in air much harder than a gasser and can suck some nasty grit and dirty air in causing pre-mature engine wear!
also, if you have a turbo (never mentioned which diesel you have... (6.9, 7.3 IDI, 7.3PS, 6.0?) but if you sport a turbo it's much easier! run a tall gearset (3.55's or maybe even taller) and you can get some wicked wheelspin if you keep your turbo pushing!
-cutts-
Old Apr 20, 2006 | 09:21 AM
RawPower's Avatar
RawPower
ditto on fishy. Prefilters are a good idea too.
Also, 5.13's and 40's on a torque monster isnt really necessary for mud. Id go with close to stock ratio.
Old Apr 20, 2006 | 09:31 AM
Customz's Avatar
Customz
5.13s would gear it like a Towboss, so it is very close to stock. Most of that gear is correcting for the tire diameter. I have 3.73 now and wish it were lower.
Old Apr 20, 2006 | 09:40 AM
KubotaOrange76
that will be pushing those headgaskets and the turbo pretty hard
not to mention the stock tranny
Old Apr 20, 2006 | 10:06 AM
Customz's Avatar
Customz
Its an 06 and the head gaskets aren't as much of an issue since they lowered compression in 05. That number is obtainable with ~30 lbs of boost. If I float the heads I will upgrade to ARP studs and c-rings. When the tranny goes I will build it. I figured the low gears would help some.
