headlight switch assembly removal?
Old Sep 8, 2002 | 07:54 PM
rcbisset's Avatar
rcbisset
I have removed all switch assy's and ***** from dash except the headlight. This assembly is loose but I cannot actually remove. Any suggestions. There is not a hex nut on the **** itself. As for the rest of the assemblies, no two were the same.
I have both those thin wood grain plates that runs behind dash *****. I would like to replace these with a chrome or stainless equivalent. Is there an aftermarket dealer, or should I try to remove wood grain finish and buff for a chrome like finish?
Thnks, rob
'69 F250 Ranger
Old Sep 8, 2002 | 09:20 PM
Sunny_in_hollister's Avatar
Sunny_in_hollister
If I remember corrrectly there is a small button on the switch assembly that you hold in while sliding the **** out. After that remove the threaded collar.
Reggie
Old Sep 9, 2002 | 08:14 AM
rcbisset's Avatar
rcbisset
Thanks Reggie, I'll look for that button during my lunch hour. I was all over that assembly last night. I noticed I was getting frustrated at such a minor thing so I had to back off before I busted it.
rob
Old Sep 9, 2002 | 08:38 AM
GolferSA's Avatar
GolferSA
That's the trick... on the top side of the switch, push it down and pull out the shaft/****.
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
golfersa@netscape.net
Check out my gallery!
Old Sep 9, 2002 | 10:43 AM
1968F250LWB's Avatar
1968F250LWB
