Loud and deep buzzing noise
Old Apr 17, 2006 | 09:01 AM
Mikes67F250's Avatar
Mikes67F250
I have a 99 exp 4WD 4.6L. Twice now I have heard a very deep and loud buzzing type sound. Almost like the annoying noise you hear on the 70"s cars if you left your keys in the ignition. But deeper sounding and louder. Almost sounds like it is coming from underneath around the tranny or something. And just under the passenger seat just past the center of the truck. No codes, and all gauges have normal readings. Any ideas on what this could be? Rpms don't change it and it stopped on its own within about 10 seconds or so. Thanks for your input.
Old Apr 17, 2006 | 02:10 PM
Onespeed24's Avatar
Onespeed24
Is this on start-up or while the truck is already running? If it's on start-up it could be your fuel pump coming on.
Do you have rear A/C? It may have somehting to do with that too...
Do you have kids? Maybe it's just a silly toy that is trapped under one of the seats...
Old Apr 17, 2006 | 02:18 PM
Mikes67F250
It does it after startup, about a mile or so after you get going. Speed and rpm doesn't change it and it is loud like a buzzer but a bit bassier. It does have rear air. But it should only do it if the air is on or the defrost right? Or does the rear have a clutch that could make that noise. I am not sure if it is the same as the one in the engine compartment or not. Thanks for the reply.
Old Apr 17, 2006 | 02:25 PM
Onespeed24's Avatar
Onespeed24
Well, there is a whole bunch of threads regarding "blend door" issues. Most people get a clicking noise from the rear A/C, perhaps this is related? Do a search for blend door and see what you come up with.
The only other things I can think of are the power lumbar in the seats powering on or maybe one of the reminder chimes is located under there and is damaged or shorting out or something...
Old Apr 18, 2006 | 08:12 AM
Sanchez_315er's Avatar
Sanchez_315er
I'd check the clearance on the heat shields on the cats. The expansion of metal through a heat-up cycle of an exhaust system can sometimes have weird sounds at certain times, but not at others.
Ford'05HG
1983 - 2012 Ranger & B-Series
May 15, 2017 04:35 AM
Lorrainethef250
Jan 26, 2017 02:08 PM
Pedersen
Sep 10, 2015 08:44 PM
theoldwizard
Aug 9, 2015 09:06 PM
mwsF250
Modular V10 (6.8l)
Jul 20, 2010 05:23 PM
