Fuel Pump Problem
Wiring diagram shows a fuel pump relay in the fuel pump power circuit, which is controlled by the computer. After the power leaves the relay, it runs thru the inertia cut off switch before going on to the fuel pump. Your symptoms are indicative of bad/weak contacts on this relay.
I do not have a clue where it is located, but possibly others on the forum can locate it.
Dialtone
Dialtone
lovemy150's
06-07-2014 05:59 AM
Thunderace31
13
12-23-2003 03:59 PM
