'90 460 no start.
Old Apr 16, 2006 | 11:06 PM
6DoubleDuece's Avatar
6DoubleDuece
'90 460 no start.
Hey guys I have a '90 F-450 that has been sitting for 2 years. I can't get it to start. I put in a new rail pump as the one that it had was bad. Now I am getting fuel to the injector rail but it won't fire. If you put starting fluid into the throttle body it will start. I have 12V to the injectors any tip's?
TIA
Brenden
Old Apr 17, 2006 | 06:03 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 17, 2006 | 01:16 PM
andym's Avatar
andym
Can you get a fuel pressure gauge on the rail? If you have 35psi there, then we know your fuel situation is good. Are the injectors firing? You can test that with a noid light, too.
Old Apr 17, 2006 | 07:06 PM
6DoubleDuece
The injectors are not firing. I don't have a fuel pressure gauge, But there is a strong spray when you depress the shrader valve.
Also when I put a test light to the injector wires it lights on both wires. Is that correct?
Thanks for the replys
Brenden
Old Apr 17, 2006 | 08:18 PM
andym's Avatar
andym
If the injectors are not firing, then you should start there. Check all the grounds, especially the PCM (computer) ground. It also could be the PIP in the distributor. It tells the computer how fast the engine is spinning and when to fire the injectors. No signal from it = no injectors firing.
Old Apr 18, 2006 | 01:07 AM
6DoubleDuece
Ok I got it figured out. There was a ton of water in the fuel drained the tank, put in fresh gas and it runs like a top Thanks for the posts I really appreciate it.
Thanks
Brenden
