Headlights Flickering
Old Apr 16, 2006 | 10:21 PM
4x4bigblock's Avatar
4x4bigblock
My headlights flicker after running it for a while. usually when on high. Could it be my floor switch? i had a bad voltage regulator but its new now.
Old Apr 16, 2006 | 10:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
4 places to look are the usual culprits:
Bad headlight switch or connector.
Bad floor switch or connector.
Bad headlight connectors.
Bad grounds.
Old Apr 16, 2006 | 10:35 PM
FordBoypete's Avatar
FordBoypete
Bad Block to body, or block to nose sheetmetal [front clip] grounding cables too.
FBp
Old Apr 17, 2006 | 12:36 AM
Mil1ion's Avatar
Mil1ion
Ford headlight systems circuitry suck big time.
They involve a circuit breaker in the switch because full power runs through it.
I suggest to do the relay upgrade to solve this problem forever.
https://www.ford-trucks.com/article/...r_Brights.html
https://www.ford-trucks.com/article/...ay_System.html
Old Apr 17, 2006 | 08:12 PM
jimlj's Avatar
jimlj
I second what Mil1ion said. Best $35 (including the new headlights) I ever spent on my truck.
Old Apr 18, 2006 | 09:46 AM
partsman01's Avatar
partsman01
I noticed a pulsatinn of my lights on my 79 truck, it stopped as soon as I held and pushed on the plug going to my voltage regulator, and gave it a good wiggle.
Old Apr 18, 2006 | 10:49 AM
Mil1ion's Avatar
Mil1ion
Yes, Grounding of electrical components is most important.
Good idea to coat the contact with d-electric grease as well.
The Headlight flicker in Fords is a well known problem though.... because of the amount of current going through the switch.
GM's don't have this problem because they use the relay system.
But then again, Gm's also have major Grounding problems on their trucks.
Old Apr 19, 2006 | 07:07 AM
4x4bigblock
what is the name of the switch, when ordering at the parts store. or do i just by passs it. i have not had time to read the links there yet . i will tonight. i want to put in silver stars also.
Old Apr 19, 2006 | 10:12 AM
Mil1ion's Avatar
Mil1ion
You need to read the articles.
The swap take a few hours to do.
People should also pay the extra money and buy the Bosch Relays.
