cool intake
Old Apr 16, 2006 | 07:43 PM
Josh0525's Avatar
Josh0525
cool intake
ok i have seen where getting an intake system for this truck is pretty much a waste, ive also seen where using insulating tape can do the same thing, can someone explain to me exactly how this is done, like what i tape up and what not, exactly what tape to use, and how much am i going to notice the difference, i live in orlando fl, so it is hot as hell down here, thanks guys
Josh
Old Apr 16, 2006 | 11:00 PM
4.9inline6's Avatar
4.9inline6
i have not yet done it but plan to....all i know is you wrap up the box with the reflective heat tape...i guess you could wrap up the hoses also if you wished....basically, whatever is wrapped in the tape will insulate the heat out. how much gain? i honestly couldn't tell you. let us know what you find out.
chris
Old Apr 16, 2006 | 11:03 PM
Josh0525's Avatar
Josh0525
alright cool, im assuing its the outside of the box you wrap?....you said your planning on doing it, what are your plans?...and where can i get this tape?...lowes or home depot?
Old Apr 16, 2006 | 11:04 PM
Josh0525's Avatar
Josh0525
oh yea and also i have a k&n filter..should i toss that $50 piece of trash?...whats the best filter you have came across?...i hear these K&n's are a waste of money
Old Apr 16, 2006 | 11:37 PM
83Van's Avatar
83Van
Plumbing in some cool air will help during summer months, but going to the trouble of insulating the air intake tube/ box probably isn't going to do anything. The incoming air is going to be moving fast enough that it's not going to pick up any appreciable heat, especially if your intake tube is plastic. If anything put an insulating spacer under your carb. You'd have to make one for the stock 1bbl, but if you're running an aftermarked 4bbl setup they're readily available in 1/2" and 1" heights. You get a boost in velocity from the spacer plus cooler fuel. Also doesn't hurt to insulate the metal fuel line going from the pump up and over to the carb. This would do little for performance, but helps prevent boilover in the summer.
Old Apr 16, 2006 | 11:41 PM
Josh0525's Avatar
Josh0525
lol well thanks but i would do this but my truck is EFI, but your saying wrapping the box and everything is not worth it?
Old Apr 18, 2006 | 10:12 AM
Josh0525's Avatar
Josh0525
any other suggestions from anyone?
Old Jun 28, 2006 | 03:41 PM
Gatsby's Avatar
Gatsby
I am rebuilding my 240 (carbed) and was thinking of ways to insulate the intake manifold, fuel line, air intake hose, and breather box. Basically I was looking into slipping header boots/sleeves over my header runners by the head and also having the outside of the intake manifold coated with a thermal reflective coating. I will probably also place a metal heat shield between the carb and the manifold assembly with a phonelac spacer between the carb and the intake manifold. Everything else--fuel line, air intake hose, and breather box--can be insulated with insulating items available from any hardware store. However, some heat in the intake system is needed to keep the fuel in the air/fuel charge in vapor form (this would include injection into intake runners as well). I don't know if this would make that much of a difference, but I'm in Mississippi, and our winter/cool weather is only a few days per year. The rest of the year is extremely toasty.
jmuenchow
Dec 2, 2014 11:46 PM
CarolinaCanes
Jan 18, 2014 12:35 PM
StumpPullerF1
Appearance & Dress-Up
Jan 3, 2011 08:27 PM
Josh88Ford
13
Sep 10, 2007 12:30 AM
white 01
Aug 30, 2005 02:57 PM
