Forced air modification question
Old Apr 21, 2006 | 07:05 PM
havi's Avatar
havi
I'll have the Roast Duck
was the driveshaft put back on exactly like it was? If not, it may be "out of phase", which can cause a vibration. rotate the tires front to back and vice-versa, and see if the rear tire still wobbles.
Old Apr 22, 2006 | 01:53 PM
eonicrush's Avatar
eonicrush
I thought we put the drive shaft on exactly as it was. How do align it properly and such or check to see if it's out of phase? I wont have access to a lift to be able to check if it wobles for a couple weeks but I can on the other hand drop the shaft within the next day or two.
Also when we had it up on the lift running it before it was only the driver side rear tire hopping, not the other one.
Old Apr 23, 2006 | 05:18 PM
Bdox's Avatar
Bdox
Balance the driver's side tire!!!!!!!!!!!!!!!
Old Apr 23, 2006 | 07:12 PM
havi's Avatar
havi
what bdox said, won't cost much at all....less than 3 gallons of gas. Trust yer memory on the driveshaft and leave it as it would wobble and not the tire if it was wrong.
AbandonedBronco
17
Jan 16, 2015 01:09 PM
bobj49f2
Jul 24, 2012 09:36 PM
hollenjoe
Apr 26, 2010 09:20 AM
neil 95 e350
Sep 7, 2008 02:47 PM
evad4321
Nov 16, 2006 01:27 AM
