Solder
Old Apr 16, 2006 | 04:44 AM
Chumbucket's Avatar
Chumbucket
Solder
What type solder is used for auto wire ? I used the plumbing type on boat one time. I mean when you sweat cooper. One of the connecter's broke off on fuel pump sending unit. One of those tinned connecter's . The only other choice might be JB Weld. to hold the 2 connecter's together.
Old Apr 16, 2006 | 08:42 AM
Ultraute's Avatar
Ultraute
Use rosin core for electrical connections. Don't use JB Weld, it doesn't conduct.
Old Apr 16, 2006 | 10:11 AM
Chumbucket's Avatar
Chumbucket
Solder
Ok, Thank's i make a few practice run's first
Old Apr 16, 2006 | 12:51 PM
Bob Ayers's Avatar
Bob Ayers
Don't use acid core solder. Try and find lead-tin (60/40) rosin core solder. Most of the solder you will find today is low-lead, or lead free, which usually requires higher temperatures, and the joints aren't as good as lean-tin.
