Bronco II Ford Bronco II
86 BII Ref voltage ???
Old Apr 15, 2006 | 06:16 PM
subford's Avatar
subford
Question 86 BII Ref voltage ???
I just finished building a sucka for the EEC and I was trying to check it out and it seems that the Ref voltage coming from pin 26 is Neg. (-) 5 volts and of course everything on the sucka is for +5 Volts.
Unplugged the EEC and plugged in a PCM from a 95 F150 to check my wiring and it has +5 Volts Ref Voltage.
Is the 86 BII (Code RC1) the only EEC that has neg. 5 volts ref voltage?
Anybody else ever run in to this?
Old Apr 16, 2006 | 01:05 PM
kernel-panic's Avatar
kernel-panic
1) define 'sucka'.
2) I haven't delved that far into what pins have what voltage on the EEC-IV ECU.
Old Apr 16, 2006 | 02:59 PM
RangerPilot's Avatar
RangerPilot
If I remember the whole lesson in Chemistry on voltage, -5 volts is the same as +5 volts, just running the wrong way. Sounds as if something is reversed?
RP
Zach
Old Apr 16, 2006 | 03:19 PM
subford's Avatar
subford
Originally Posted by kernel-panic
1) define 'sucka'.
The best way to describe or define sucka is to go to this URL
http://www.austincc.edu/cloud/efi/amarch/eecsucka.htm
It sucks (copies it to a file in your computer) the program out of your ECU than you and look at the program that you are running on.
Old Apr 16, 2006 | 03:26 PM
subford's Avatar
subford
RP
Zach
No I left the setup the same, just plugged in the other EEC (ECU) and pin 26 of the breakout box had the opposite polarity.
Thanks for the replies
Old Apr 16, 2006 | 09:18 PM
kernel-panic
AH. Okay. I looked up some info on EEC-IV tuners/tuning, and it seems (AS USUAL) anything tuning/performance related is always pointing at V-8s or cars in general -- not something like a BII or Ranger. It would, though, be pretty kickass to dump the program file somewhere where you can look at it, edit it it, then flash it back to the computer's EPROM instead of paying for a chip that plugs into the service port. Ah, well. *shrug*
john165
Jul 21, 2012 06:09 PM
mzdb4000
1983 - 2012 Ranger & B-Series
Feb 3, 2008 12:50 PM
TrucksNamed"PHIL"
Apr 1, 2007 08:58 PM
timbarr
Aug 4, 2003 07:55 PM
crazylegs
Electrical Systems/Wiring
May 27, 2003 05:25 AM
