Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Media Blasting materials
Old Feb 26, 2002 | 04:24 PM
robertr's Avatar
robertr
Post Media Blasting materials
I have several projects that will need "sandblasting" to fully clean and prepare for further work. One company in Canada sells a material they call "K2" which turns out to be potasium sulphate I understand. Are there any of you out there that have had work done using this product, and are there sources to buy this material more directly. Any sandblasting company is going to have to mark it up a batch just to pay for inventoring it and so on. Also the "K2" stuff is supposed to be the least problematic for cleanup after the blasting is done. Is that true? Any other info on this product would be appreciated.
Old Mar 4, 2002 | 11:21 AM
sb2371's Avatar
sb2371
Old Mar 9, 2002 | 10:35 AM
Greywolf's Avatar
Greywolf
That stuff sounds like the fine material used in electronic chassis rehabilitation. It is not the sort of an abrasive I would use on steel at all, more like for cleaning circuit board connectors or mild aluminum chassis areas (in electronic assemblies).
Normally glass beads are the preference of choice, and they are readily available.
Both potassium and sulphur are water soluble, but they are also potentially CORROSIVE. Sulphur readily forms sulphuric acid under some conditions and Potassium can combine into a salt. These are not desirable materials at all in large scale operations, because cleaning would have to be very thorough in order to prevent any left over material from hiding out in crevices to potentially become much more damaging than the original rust.
Glass beads on the other hand are inert - glass is a form of silicon.
Old Mar 9, 2002 | 06:23 PM
Boss_358's Avatar
Boss_358
What about Silica sand?
Old Mar 9, 2002 | 09:45 PM
51frrdtrk's Avatar
51frrdtrk
If you want to remove paint i would use glass beads. If its rust you should try aluminum oxide. I use this in my cabinet for small parts it works great. Cost about $32.00 bucks in the Detroit are (50 pound bag). For my larger projects i use silica sand its cheap.
Watch when your blasting those body parts. Its real easy to warp a body panel..
I had my 68 Vette stripped last year and they used glass bead ($800.00).
Old Mar 10, 2002 | 05:13 PM
Greywolf's Avatar
Greywolf
One further note: BEWARE OF BEACH SAND!
Unless it's from an inland lake, sand from the ocean front is loaded with salt - an underbody/frame's worst enemy. In theory you can leach the salt out of it, but why even bother?
It's cheap enough to get the right stuff...
Old Mar 12, 2002 | 12:45 PM
aerocolorado's Avatar
aerocolorado
Potassium sulfate is a chemically unstable compound that deteriorates readily on exposure to oxygen, moisture or carbon dioxide. Unless they have some method of stabilizing this compound, which would add cost, there are sure a lot of cheaper alternatives. This compound is also known as Sulfurated Potash. When exposed to air it produces a distinctive odor of hydrogen sulfide, that lovely rotten-egg smell.
Old Mar 15, 2002 | 11:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
Has anybody heard of that plastic bead material? It is supposed to be safe on fiberglass and won't warp sheet metal.
over!
Drive 'em forever!
Old Mar 15, 2002 | 11:34 PM
Mil1ion's Avatar
Mil1ion
I mentioned it on a another thread in this forum.
It has become the normal here, for Best quality/Low Chance of damage material for blasting.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
[font color=blue]Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [font/]
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Mar 16, 2002 | 09:04 AM
Boss_358's Avatar
Boss_358
What do the plastic beads look like? The only other stuff I have used besides silly sand is this black blasting crystal stuff. I don't know what it is really made of though. Another thing that might help is having a decent sandblaster. Are pressure blasters still $400. :-staun
Old Mar 16, 2002 | 11:15 AM
Mil1ion's Avatar
Mil1ion
Here's the lowdown.
http://www.surfaceblasting.com/plastic.html
84 Volvo DL Wagon
Old Mar 16, 2002 | 12:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks for the Link!
Pressure blasters (smaller homeowner varieties) can be found at Harbor Freight Tools and Northern Hydraulics. I have a 40 pound pressurized unit from Harbor Freight #34202-1VGA that I bought for $75, they are $80 now. It is a very, well made unit and should still be around for my grandchildren, I am quite happy with it.
http://www.harborfreight.com/
http://www.northern-online.com/
over!
Drive 'em forever!
green_95
Jan 12, 2016 03:58 PM
cody919
23
Aug 28, 2015 08:13 PM
FossenRacing
Jan 15, 2015 06:21 PM
Indybroncoman
Paint & Bodywork
Sep 30, 2003 11:26 AM
