pre or post 79 460
Old Apr 14, 2006 | 09:44 PM
jjz 109's Avatar
jjz 109
pre or post 79 460
Is there an easy way to tell the difference between an internal vs. an externally balanced 460 other than casting numbers?
Old Apr 14, 2006 | 09:48 PM
bbfan's Avatar
bbfan
counterweigth behind balancer
externally balanced engines have a sledge, the other doesnt.
Old Apr 14, 2006 | 09:51 PM
jjz 109's Avatar
jjz 109
When you say sledge, is this the counterweight on the balancer?
Old Apr 14, 2006 | 10:00 PM
bbfan's Avatar
bbfan
its the counterwieght behind the balancer.
Old Apr 14, 2006 | 10:18 PM
sirfranky's Avatar
sirfranky
sorry to jump
Is there any problems with this during a rebuild as per se the machine shop or is it just up to you to put the harmonic balancer back on. tha reason I ask is that I am doing a rebuild I have two engines one with one without? So I figure I better ask now thanks
Old Apr 16, 2006 | 03:48 AM
jamies460's Avatar
jamies460
Hello, depends on what type of 460ci you are planning to build, if its going to be a High revving 460ci it would be best to go for a INTERNAL balance engine, but if its going to be a every day driver not seeing over 6'000 revs a EXTERNALY balanced 460ci will be fine . Jamie. Australia
