Trans leak
Old Apr 14, 2006 | 08:20 PM
mrl390's Avatar
mrl390
Trans leak
The E4OD transmission in my 93 F150 is leaking. It seems to be coming from the back of the transmission pan. Am 99.9% sure that the pan is not leaking. Any suggestions on what else could be leaking? Any help would be appriciated. Thanks.
Old Apr 30, 2006 | 09:58 AM
twisted_metal's Avatar
twisted_metal
check out the shift linkage on the side of the trans. theres a seal there. thats where mine leaks. also check out further ahead for the oilpan,rear main and front seal from the trans. the fluids will stream backwards and make it look like the trans is the problem even tho sometimes its not.
Old Apr 30, 2006 | 12:50 PM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum.
