Gear Swap ????
Old Apr 14, 2006 | 03:41 PM
bsw9323's Avatar
bsw9323
Gear Swap ????
I am planning to do a gear swap on my 1989 f150 4x4. I currently have 3.55(8.8) in the rear and 3.54(dana 44)in the front. I will be going with 4.10 rear and 4.09 in the front. This is the ad for the front gear "4.09 Ratio; Reverse Cut; Dana 44 Front Axle; Fits 3.92 & Numerically Higher Carrier" My question is, is this the correct gear for my differential? And what does it mean by "Fits 3.92 and Numerically Higher Carrier? thanks
Old Apr 15, 2006 | 06:43 AM
2020's Avatar
2020
I don't know about the Dana,but some 9 inch carriers had a factory relief made in the rear pinion bearing boss .You have to take a die grinder and clearance the casting to clear the ring gear on the 9 inchers when installing the deeper gears,(4.11,4.56,etc.).The deep gears have thicker ring gears so sometimes they need to have a little modification.
Old Apr 15, 2006 | 02:57 PM
kennethl6's Avatar
kennethl6
If you get a 4.09 gear, you'll have to get a new carrier with a different ring gear offset.
Old Mar 5, 2009 | 11:29 PM
stangbanger's Avatar
stangbanger
where would one get this carrier?
