timing help!
Old Apr 14, 2006 | 02:16 PM
WoomaHodal's Avatar
WoomaHodal
timing help!
alright in august, when i was done rebuilding the engine, and putting it all back together, i did the timing. i didnt really konw what i was doing, but i did it good enough to last nearly a year working fine.
well i checked it today, and it was at like 40 degrees or something. REALLY off. when i made it closer to the 10 degree mark, it got worse and worse. if i moved it the other way, it ran better, but if i go too far it starts missing.
i dont know what to do.
Old Apr 14, 2006 | 02:59 PM
quicklook2's Avatar
quicklook2
what year?
do you know what a spout is?
did you remove it?
Old Apr 14, 2006 | 05:42 PM
WoomaHodal's Avatar
WoomaHodal
its an 81 with the i6. i dont know what a spout is, unless thats the vacuum advance. i did block off the vacuum advance and the yellow line that runs into it
Old Apr 14, 2006 | 06:18 PM
mikestrawn's Avatar
mikestrawn
It could be that your harmonic balancer hub has slipped. You need to put #1 piston at TDC on the compression stroke and see if the timing marks line up. If it is way off, get a new harmonic balancer and reset the timing.
Old Apr 14, 2006 | 07:07 PM
WoomaHodal's Avatar
WoomaHodal
hmm i didnt know there was timing marks. i just drew a line with a crayon
Old Apr 14, 2006 | 08:15 PM
quicklook2's Avatar
quicklook2
you are just kidding, right?
Old Apr 14, 2006 | 09:20 PM
WoomaHodal's Avatar
WoomaHodal
nope. i had a hard time getting my 4 year old sister to let me borrow a pink crayon too.
Old Apr 14, 2006 | 09:30 PM
beatupford's Avatar
beatupford
put the crayon in #1 cylinder, get the lite brite and the colouring book, and go from there.
Old Apr 14, 2006 | 09:52 PM
mikestrawn's Avatar
mikestrawn
Whatever fella, you asked for help and you got the correct answer. Get your sister to help you swap the HB.
Old Apr 14, 2006 | 10:29 PM
WoomaHodal's Avatar
WoomaHodal
the harmonic balancer is fine. the timing marks are fine too.
Old Apr 15, 2006 | 07:35 AM
n9lhm's Avatar
n9lhm
Then I would suggest that your plug wires are shifted one hole in the distributor cap. 6 cylinder engines fire every 60 degrees, and that sounds like about how far you're off. Brian
