Sponsored by: Innova
front/rear speakers?
Old Apr 14, 2006 | 12:55 AM
69ford99's Avatar
69ford99
Got a '96 bronco and am running some 4 way 6 1/2" up front but not sure if I should run 4 way 6X8 or 2 way 6X8 in the rear? I'm also running a 10" sub if that matters.
Old Apr 14, 2006 | 07:57 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
I think the multiple channels is completely exagerated. The ones up front have enough levels of sound, so there really won't be any benefit with doing that in the back speakers. I'd just go with the 2 channel. You already have high range up front, now you need lower-mid range, and you already have subs.
Ryan
Old Apr 14, 2006 | 09:30 AM
deltasoft's Avatar
deltasoft
yup i believe same fghtin.....4- 6 X8 spkrs, and sub is all he needs for basic setup....for pro setup add some tweeters on front doors and crossover......
Old Apr 14, 2006 | 02:12 PM
furball69's Avatar
furball69
I am in agreement; anything over 2 way is a gimmick. If you can make a good 6.5, 2 way work, I'd go with that.
Old Apr 14, 2006 | 08:29 PM
IPACA9's Avatar
IPACA9
I would recommend the DB Drive Platinum PL5.7. They are a 5x7 coaxial with a crossover. Since you're running a subwoofer you don't need your speakers trying to run that low signal leaving room for powerful midbass and piercing highs. These speakers smooth it all out.
