A/C problems
Old Apr 13, 2006 | 10:52 PM
H1449-6's Avatar
H1449-6
A/C problems
I have a 2000 Ex V-10.
I have two problems with my A/C, discovered only as it heats up here in the mid-South.
First, the A/C is always on. If the switch is in any position but "off," the A/C compressor seems to be on. If I move the switch to positions that are other than A/C, the compressor seems to continue to run. Any ideas what need to happen here?
Also, and perhaps because the A/C is always on, it doesn't blow very cold. I suppose I must need a recharge.
Anyone else experience these problems? If so, what do you think I'm up against and how much do you think it may cost?
Thank you.
