89 302 stalling problem,
Old Apr 13, 2006 | 10:42 PM
87f150xlt's Avatar
87f150xlt
I have a stalling problem with 89 F150 with 302. Starts up fine and hold idle good but stalls when come to slow down after driven up to faster speed. should I just replace IAC valve?
Old Apr 14, 2006 | 11:05 AM
andym's Avatar
andym
Here's what I'd actually do. Take the whole throttle body off and scrub the plates with a stiff brush and plenty of cleaner - some people use throttle body cleaner, but I maintain that it's the same stuff as brake parts cleaner, carb cleaner, etc. in a different can. Make sure you soak the IAC good and if it's too gummed up, replace it. Also think about replacing the TPS while you have it apart.
I did this a few weeks ago to the Bronco and it idles SO much smoother now.
