starter makes noise
Old Apr 13, 2006 | 12:29 PM
ddmoyers's Avatar
ddmoyers
starter makes noise
The starter on my '87 ford f-150 300 efi straight six makes a lot of noise. what could cause this to happen and how can i fix it. I starts ok but it makes a grinding noise.
Old Apr 13, 2006 | 12:56 PM
gatesj's Avatar
gatesj
Does it grind, then you let off and try again and it starts, basically when it grinds does it turn the motor over?
Take the starter off and take a look at both the bendix drive (pinion) gear on the starter and the ring gear in the bellhousing. Make sure they aren't chewed up.
