Transfer case Help!
Old Apr 13, 2006 | 07:00 AM
Concept25's Avatar
Concept25
Transfer case Help!
My 91 f350 won't stay in gear , keeps popping out, seems to be the transfer case shift won't engage ?????????
Old Apr 13, 2006 | 07:08 AM
PLC7.3's Avatar
PLC7.3
Visit......... http://www.zf-group.com/am/pc/lt/ampclt02.phtml for troubleshooting ZF5-42
Old Apr 14, 2006 | 08:05 PM
drz400gncc's Avatar
drz400gncc
is it your tranmission or transfer case thats popping out.
Old Apr 14, 2006 | 08:25 PM
dieself250's Avatar
dieself250
I would assume your truck is 4x4, if so the borg warner 1356 transfer case is well known to have the shift fork wear out on the 2hi and 4hi range. also the oil pump is known to fail. I had the shift fork fail on mine 4 months ago. when it happened i thgought my cluch went becase it was fine up to 4th gear and then in 5th it felt like it fell out of gear. i found out that 4low worked fine and if i kept pressure on the shifter, keeping it the 2hi position it would say in gear. i rebuild my transfer case for about 200 bucks it only took a few hours to do
