Urban Myth
Old Apr 13, 2006 | 06:47 AM
OzFTrucker's Avatar
OzFTrucker
Question Urban Myth
G'day guys, I read(or heard, can't remember) years ago that you could diagnose a cylinder with no compression as rinds/pistons or valves by putting a piece of paper over the exhaust. The story went that if the paper sucked back against the end of the pipe for a split second every cycle that the problem was a valve, just wanting to know what you guys think/know. I have a 351C with a dead cylinder that I have to fix so I tried the paper trick first and it sucks in, want to know if it is an engine out fix or just a heads off.
Old Apr 13, 2006 | 09:20 AM
Homespun91's Avatar
Homespun91
One method, if you've got access to a compression tester, is to get a baseline reading; then shoot some heavy oil into the cylinder, spin the crank a few times, & retest. If the reading now goes way up, it's the rings. If not, it's the valve(s).
Doesn't hurt to repeat this a few times to make sure you are fully coating the cylinder walls with oil. Good luck-
Old Apr 13, 2006 | 09:46 AM
beartracks's Avatar
beartracks
If you have a burned exhaust valve the paper trick will show it. You can usually hear it at the tail pipe.
Old Apr 13, 2006 | 03:55 PM
OzFTrucker's Avatar
OzFTrucker
To me it doesn't sound "poppy" enough to be a burnt exhaust valve but also it isn't making any engine noise so I doubt it is a lifter or holed piston, I would just like to find out before I go and pull the engine.
Old Apr 13, 2006 | 09:03 PM
Tech-man's Avatar
Tech-man
If you introduce compressed air into the cylinder, it should hold or it could give you 3 possible symptoms: air coming out tailpipe(burned EXH valve), air coming up thru carb(burned INT valve), or air trying to escape thru dipstick tube or oil filler cap/pcv valve( excessive blowby, cracked or stuck rings). None of the last 3 things are a good thing.
