front axle question
a freind of mine has a 79 f350 460 , factory was a 2wd but now is 4wd, the hub broke on it and he cant find parts for it. the front pumpkin is on the passenger side he thinks its a (4.10 or 4.11) Dana 70 (numbers say like M70 but i cant remember) so is that military? there is a tag on the door that is like 6inches by 6 inches that tells where it was built at its in kentucy or tennesse-he called them and they are out of buisness now. im kinda thinking it came out of a dodge but not sure. it has leaves- lots of leaves- and on the frame you can see all the old coil spring mounts and etc. i dont know how to put pictures on here or i would mostly becouse it looks like a bad sob
Here is the link:
http://77cj.littlekeylime.com/images...sFordother.gif
Hope this helps
he didnt break the axle he broke a part in the hub not to sure what but he said it looked like a gear just behind the lockout. he went to ford and they couldnt find the part so i looked it up in a magizine for gears (reider racing) and i guessed dodge but wasnt to sure
