Driveshaft Vibration
Old Apr 12, 2006 | 09:02 AM
chapfr's Avatar
chapfr
Thumbs up Driveshaft Vibration
2005 X 6.0 PSD , I have installed many Mods , Banks Big Hoss Bundle with PDA , 18 inch wheels , 35 "Nitto,s 3.5 Spring Hanger lift. My question is if anyone has had any luck with getting the driveshaft balanced to eliminate vibration , it vibrated at 70 to 80mph while stock and appears to be exagerated more with the 35,s . The Banks System is unbeleivable , this beast is a powerhouse.
Old Apr 12, 2006 | 10:42 PM
cumminpwr11's Avatar
cumminpwr11
have a suspension shop check the pinion angle. You will be suprised what a few degrees will do.
Is your shaft a two piece or one?
are there blocks on the rear? If so, you might need some shims.
Chris
