Sponsored by: Auxito
97 4.6 engine problems
Old Apr 26, 2006 | 11:37 AM
skilife17's Avatar
skilife17
Originally Posted by FourthFordTruck
How many miles on your truck? Since it's a '97 4.6, like mine,
I suggest the following: Replace your IAC, clean your MAF,
clean your throttle body egr ports of the carbon buildup,
replace the egr while your at it, reset your computer and
see how good it runs. All 4.6's will need the above sooner or later.
Mine was done around 127,000, or two years ago. It will not run worth
a crud with the above problems. You can do the work yourself. Good luck.
I have a 97 4.6 w/182700mi and I am not sure if any of these things were even done on mine. The truck runs great and has plenty of power. Should I keep an eye on these items?
Old Apr 26, 2006 | 01:29 PM
JTM80's Avatar
JTM80
the truck has 126,000 miles or so on it. Thanks for the info fourthfordtruck. I will give that a try and see what happens. It sure can not run any worse!
bismic
Nov 23, 2016 07:43 AM
JWink
Aug 29, 2015 02:21 AM
EALightingSolutions
2009 - 2014 F150
May 17, 2015 09:45 PM
f150crewcab
Mar 6, 2015 03:15 PM
