Sponsored by: Real Truck
Rear speaker replacement
Old Apr 11, 2006 | 12:43 PM
jelmore's Avatar
jelmore
On a 2006 regular cab, how do you get the panel out to get to the speakers. I got the door speakers replaced with no problem but I can get the panel loose on the rears. Don't want to break anything.
Thanks, John
Old Apr 11, 2006 | 04:09 PM
FortyFords's Avatar
FortyFords
On the regular cab the speakers are in the corner trim or the back panel?
To remove the back panel ,the corner trim has to come out first.Which means the scuff plate pops up ,the weather strip has come off around the rear of the door opening.the seat belt retracter has to come out,then fed through the corner trim piece.
For the back panel if your truck has the utility traysabove the panel they have to be removed,then there are 4 push pins that need to be removed.
Rich
Old Apr 11, 2006 | 04:30 PM
jelmore's Avatar
jelmore
They are in the corner trim. I got the top to pop loose, one clip at the front and looks like a push pin at the rear of the trim. I didn't try to move it any more.
Thanks
