351M Fuel Pump
Old Apr 11, 2006 | 11:16 AM
kd123's Avatar
kd123
351M Fuel Pump
This is a easy question (I hope) ....On a 351M fuel pump, which side is the inlet and which side is the outlet of the pump? When I stripped the truck down to the frame (months ago) I never marked them and there is no markings on the pump.
Old Apr 11, 2006 | 12:44 PM
LilDuke's Avatar
LilDuke
The inlet should be on the bottom, and outlet(to carb) is above it. If I remember correctly, it should be a rubber hose clamp type connection on the bottom and a 1/4" threaded connection above for the metal fuel line to carb.
Old Apr 11, 2006 | 01:42 PM
kd123's Avatar
kd123
Actually the inlet/outlet are side to side, but one is threaded and one is barbed for a hose. So the threaded side should be the outlet to the carb?
Old Apr 11, 2006 | 02:23 PM
LilDuke's Avatar
LilDuke
Right. Been a while since I looked.
Old Apr 11, 2006 | 03:49 PM
fordborn's Avatar
fordborn
Thread moved to "335 Series- 5.8/351M, 6.6/400, 351 Cleveland" tech forum. Should find more resources here for your question.
Speedymaru
Aug 21, 2016 09:16 PM
bjmayberry2
13
Oct 6, 2015 07:42 AM
buckbr549
Jun 20, 2010 10:58 AM
wyazel1
16
Apr 9, 2007 06:17 AM
