Jumping into drive
Old Apr 11, 2006 | 06:38 AM
725franky's Avatar
725franky
Jumping into drive
1994 F150 XLT 4X4 E4OD
Hi my truck has been like "jumping into gear". When I first put it into drive it kind of lurches forward. It also does something simular when I put it in reverse but much less sever. I check my u-joints and there didn't apear to be any slop in them. Anyone know what the cause might be? Oh yeah, it only does it when initially put into drive; not when I take off from a stop, just when I first put it into gear. All help is greatly appreciated, thanks in advance.
-Frank
Old Apr 11, 2006 | 09:00 AM
spidk43's Avatar
spidk43
the same kind of thing happens to me... its more severe when I put it in reverse. Just got my entire front end done... Sometimes it does it more than other times-usually the first time its put in gear. I just keep my foot down hard on the brake when I'm shifting and it doesn't rip my head off... hehe (it really isn't that bad) It hasn't been a problem to me yet anyway. Good luck.
~Matt
Old Apr 11, 2006 | 10:12 AM
725franky's Avatar
725franky
It isn't a problem yet for me either. But, that's why I want to find out what it is; so it doesn't become a problem.
-Frank
Old Apr 11, 2006 | 10:49 AM
LoosMaster's Avatar
LoosMaster
When was the last time you did any maintenance on the tranny, like fluid and filter?
Old Apr 12, 2006 | 05:30 AM
725franky's Avatar
725franky
I have not done that since I bought the truck (about 11 months ago, only about 2000-3000 miles ago).
Old Apr 12, 2006 | 08:32 AM
LoosMaster's Avatar
LoosMaster
Next question. Does it do it all the time or just when you first start the truck(ie,cold or hot).
Old Apr 12, 2006 | 10:38 AM
725franky's Avatar
725franky
I beleive that it does it all of the time.
Old Apr 17, 2006 | 07:41 AM
725franky's Avatar
725franky
I changed my trans fluid and filter....still when I first put it into gear it's overly eager to go.
Old Apr 17, 2006 | 10:43 AM
depotops's Avatar
depotops
Does that truck have cruise? Mine is like the exat same truck and it was doing that too... turned out when i braked while cruise was engaged it would do that... to fix it i just poped the hood, move the little guard by the throttle and moved with my fingers the spring loaded thing you can use under the hood to rev the engine (sorry dont know its techincal term lol)...
that fixed my problem, Im not saying yours is the same but all it was for me was the accelerator cable was almost like stuck just a tad down because of that thing. hopefully its something simple like that, doesnt cost a dime
Old Apr 17, 2006 | 11:17 AM
725franky's Avatar
725franky
Yeah, my truck does have cruise, but I almost never use it. And that black cover is off on my truck already and I haven't noticed the cable to be sticking....will double check just to be sure though.
Old Apr 17, 2006 | 12:22 PM
depotops's Avatar
depotops
yea it never hurts to check it and lube it up a little too... could be all it is. some wd-40 perhaps...
Old Apr 17, 2006 | 12:42 PM
felixr's Avatar
felixr
same problem here. mine takes a second to get into drive. for instance, i start the truck and put it in reverse to pull out of my driveway and as im in the middle of the street i put it into D and it just sits there for 2 seconds then jumps into gear. back when i first bought the truck and didnt know it too well, i put it in D and revved to move away and when it finally got into gear it jumped like 4 feet lol and gave an awefull feeling throughout.
so is my transmission failing? whats going on here?
Old Apr 21, 2006 | 09:00 AM
felixr's Avatar
felixr
have recently paid more attention and what it seems to be doing is its like getting stuck in gear and over revving a bit and then going into gear.
bought some seafoam trans tune and will get some dr tranny from napa this weekend
Old Apr 21, 2006 | 09:17 AM
depotops's Avatar
depotops
Hmm defiently sounds more serious than a stuck cable... I'm not sure what that is but I'm sure someone else here will have an idea.
Old Apr 21, 2006 | 09:25 AM
725franky's Avatar
725franky
I wish I could figure out what is causing my our trucks to do this. Is it a problem with the transmission? With the differential? Transfer case? or is it just not a big deal?
