HELP! Hood won't shut
Old May 1, 2006 | 12:15 PM
jgurland's Avatar
jgurland
Awesome. Thanks, AX. My bolts have clearly been replaced, but no washers or anything. To cure my "hokey pokey" problem, I'm going to try greasing the hinges without removing them to see how it goes. I'll also try moving my latch back toward the firewall as mentioned above to see if the gets the hood to slide back and down.
Thanks again.
Old May 1, 2006 | 12:23 PM
AXracer's Avatar
AXracer
Check out my extras gallery for pix of a pivot on the hinges that often freezes. Take the spring off and make sure that pivot is free. Moving the latch AWAY from the firewall is the correct direction to pull the rear down.
Old May 1, 2006 | 12:43 PM
jgurland's Avatar
jgurland
Originally Posted by Jag Red 54
It sounds like you have the front plate adjusted too far to the front. If it's pulling the hood foward as the pin goes into the locking hole, then the hood cannot drop into place in the back. As the pin is going into the hole can you see if it appears to be hitting to the rear of the hole. From reading Ax's posts it seems to me that having the pin hit the pront edge of the locking hole may be the way to get the hood to close correctly. Try adjusting the plate and see if you get any improvement. This may be the most common problem there is among effies with the stock hood. BTW, the springs are necessary. They actually pull the back corners down once they get to the correct position. Jag
Hey, AX, I'm confused. You're saying to move the latch FORWARD - that's the opposite of what Jag said earlier in this thread. He says move the latch BACK so it pushes the hood backward into its seat. Which is correct?
Old May 1, 2006 | 01:00 PM
AXracer's Avatar
AXracer
Moving the latch forwards is correct if the hinges are working properly. It needs to be stretched out to pull the back down. I know it sounds backwards, but it's the way it's designed to work. The latch plate is difficult to get to move, at least mine was. Mark it's location on the latch panel, unbolt it completely then reinstall it further forwards.
Old May 1, 2006 | 01:33 PM
Jag Red 54's Avatar
Jag Red 54
Sorry about the confusion on forward or back. I guess there is no real correct answer until you know how your latch is positioned. So, depending on where you currently have it placed, the latch may be positioned too far forward or back. From the way yours was behaving, it seamed to me that your latch needed to be be adjusted back. But, without being there to look at the pin as it goes into the latch, I am only giving you my best guess. So, if it looks like the latch and the pin are lining up in such a way as to to push the hood back, then yes, you need to reposition it toward the front. Give it shot both ways until you get it to work. Then report back and tell us what worked and what didn't work. Good luck, Jag
Old May 1, 2006 | 01:40 PM
jgurland's Avatar
jgurland
Will do, Jag. Thanks for the reply.
Old Aug 9, 2023 | 10:42 PM
Pappys53's Avatar
Pappys53
Originally Posted by AXracer
The bolts should have shoulders on them (slightly larger unthreaded area) that prevents them from clamping the hinges tight. There is also a wavy washer that goes on to keep them from rattling. The heads are drilled for safety wires so they won't unscrew. They strip out of the hood so sometimes they have been replaced with plain bolts. Mid Fifty sells oversized threaded ones to replace stripped ones. There are two sizes, the 53-55 are smaller diameter than the 56. The 56 hinges will work on 53-55 if you use the larger shoulder bolts (the threaded portion are the same size).
where does the wavy washers go?
Spoiler
Old Aug 9, 2023 | 11:13 PM
AXracer's Avatar
AXracer
between the bolt head and hinge as I recall.
mcp1
Escape & Escape Hybrid
Mar 21, 2016 03:25 PM
GreatNorthWoods
15
Feb 29, 2016 06:54 PM
macian
Sep 13, 2004 09:51 AM
padd54
May 25, 2004 09:20 PM
karljay
May 10, 2002 08:18 AM
