General Diesel Discussion
experiences w/ additive engine restorers
Old Apr 10, 2006 | 06:55 PM
sturoe's Avatar
sturoe
I was at walmart and for the heck of it i looked at some of there diesel additives that i guess you mix with oil or fuel or something. I don't know how any of these work or if they do at all.
Old Apr 10, 2006 | 08:24 PM
JD717's Avatar
JD717
I dont know myself. though I'm skeptical anyways. only thing I'll put in my own engines is fuel and oil. the way I figure it, when a motor starts needin stuff like the engine restoring stuff, its probably time to tear it down and pay attention to really worn out parts anyhow.
Old Apr 10, 2006 | 08:30 PM
slowmans's Avatar
slowmans
i use diesel kleen in every tank of fuel, my opinion is that it helps my mileage and engine seems to run smoother and quieter? lots of guys on here use it it also has lubrication benefits too..
Old Apr 11, 2006 | 08:19 AM
saftman's Avatar
saftman
Fuel additives are almost a necessity, but I would stay away from oil additives. If your oil needs an additive you need to do an oil change or start using a better quality oil.
Old Apr 11, 2006 | 10:02 AM
FleetFilterBrian's Avatar
FleetFilterBrian
Many people use them in every tank, but I use them every 20-30k miles or so just to clean up the injectors and anything else that's in there.
They are not required - you can skip the whole thing if you'd like.
