FE Overbore
Old Apr 10, 2006 | 06:26 PM
F100Ranger's Avatar
F100Ranger
Question FE Overbore
How far can the typical 352/360/390 blocks be bored?
If I can locate one, I will be using a 3.98" stroke crank to make a 410 in3 motor, 3.78" stroke crank if not avarilable. I have a '66 352 standrard (4.00"); a +.030"(4.080") '72 360; and a '70 +.030" (4.080") 390 marked with mirrored "105". Which would be the best canidate for a rebuild/overbore that would not cause over heating problems?
Is 4.110" (360/390 +.060" over bore) the limint, or will they go to 4.130" (410/428 std), without over heating?
Old Apr 10, 2006 | 06:29 PM
ford390gashog's Avatar
ford390gashog
try the FE forum. but there is no need to bore it out more than it needs. you can bore it out to the standard 4.05 390/360 bore and add in a 428 crank and make a nice 410.
Old Apr 10, 2006 | 09:52 PM
BobbyFord's Avatar
BobbyFord
I'd stay away from anything over .040
Old Apr 11, 2006 | 07:47 AM
390fe's Avatar
390fe
I wouldn't bore it out any more than what's necessary to clean up the cylinders for proper ring sealing.
If you do feel the need to hog out your cylinders, then pay a shop to sonic check the cylinder walls so you know exactly how much wall you have. Nothing worse than breaking into the water jacket with a .040 overbore.
If you want inches, buy a crank.
Old Apr 11, 2006 | 03:25 PM
ford390gashog
he will need at least .050 to make it a 4.05 bore , the block should handle .080 just fine.
Old Apr 11, 2006 | 03:51 PM
BobbyFord's Avatar
BobbyFord
It'll run hotter at .080 over.
Old Apr 12, 2006 | 04:47 AM
gtex's Avatar
gtex
It depends on what block he uses!
I like the Mirrored 105 block if its good at .030 over. It will probably go another .030 over (.060 total) if needed and might even go a total .080 over to make a 4.13" bore. See if you can get a rough idea of what it would take to clean up the bores then have it inspected at a machine shop.
my 2 cents
Old Apr 12, 2006 | 06:12 AM
scamardo's Avatar
scamardo
You won't get better advice than whats given above there.
My 390 was recently rebuilt and safely bored out another .030 to 402.
Old Apr 12, 2006 | 08:14 AM
F100Ranger's Avatar
F100Ranger
Thanks guys, Sounds like to me the '66 352 would be find going to a std 390 bore (4.05"); the '70 +.030" 390 mirrored 105 might be ok at +.060" and questionable at +.080". Hope to pull one of these down this summer/fall for rebuild. Will try to locate someone in the Atlanta area that can do a sonic check on the walls before boring.
Question? When FORD made the 428's, did they use the same castings as the 352/360/390? If so, maybe the smaller units will be safe to inch up. Or is the 428's a unique block, and has larger capacity? Can only hope that FORD took the easy route, and had extra thick walls in the smaller units.
Old Apr 12, 2006 | 10:22 AM
Bear 45/70's Avatar
Bear 45/70
The 406 in 1962 was the first 4.13 bore block. And that's basicly what the 428 block is.
Old Apr 12, 2006 | 11:13 AM
390fe's Avatar
390fe
The 428 block is a different casting than your 352/390 castings.
Old Apr 12, 2006 | 11:37 AM
rusty70f100's Avatar
rusty70f100
A lot of the mirror 105 blocks were cast with 428 cylinder wall cores. This means you've got a lot of beef there for overboring. This is definately the block I'd use.
I'd limit the overbore to .060" without sonic checking though. You dont know how bad it's core shifted without checking it. With a sonic check, go with the results. Look at the wall thicknesses, and bore accordingly. I'd leave at least .2" wall thickness after boring.
Old Apr 12, 2006 | 03:26 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Try Southern Automotive. www.southernautomotiveengines.com They are south of Atlanta. Bill has quite a collection of FE engine parts you can oogle over besides. They can sonic the block and any do machine work if you need it. Do a search here for the "drill bit test". That's a easy way to check what cyl wall cores your blocks were cast with before you have them sonic mapped. This way you'll know if one of the blocks is a good 4.13 bore candidate before hand. Just a thought.....
G.
