Sponsored by: Real Truck
Front axle help
Old Apr 10, 2006 | 03:35 PM
tuke's Avatar
tuke
Front axle help
Hi all, I'm kinda new at this 4x4 thing so bear with me. I'm in the process of doing the front brakes and greasing the hub bearings. Well brakes are going fine. But after removing the hub assembly, the part with the needle bearings in it that I'm going to regrease. I noticed the seal that goes into the axle past the U-joints is flopping around. I can also move the axle around about a 1/2" or so where it goes into the axle housing. Should I be able to move it? The U-joints seem to be fine along with the ball joints. Any thoughts, suggestions should these seals be replaced while I'm in there? Thanks Tuke
Old Apr 10, 2006 | 06:38 PM
DetailerDave's Avatar
DetailerDave
I can't answer about the seal, but without the wheel bearing/hub installed, The axle should have some play. The needle bearing and the hub support the outer end of the axle.
Old Apr 24, 2006 | 12:03 PM
mostoyzwinz's Avatar
mostoyzwinz
all that is normal...unfortunately. I'm in the process of doing the whole knuckle deal. You might want to check out this thread, racerguy did a fine job explaining with pix how to replace the balljoints. The thread won't address your question but it clearly shows what you're talking about is normal. https://www.ford-trucks.com/forums/s...d.php?t=354091 Hope it helps...two weeks after the fact.
Old May 7, 2006 | 08:37 PM
mostoyzwinz
clarification, it's normal but not the way it is when new. due to the movement you describe, which is typical, the seal gets wipes out and separate into two pieces. one part stays fixed to the axle, the outer shell comes loose and flops around...absolutely ****ty design.
dpilot83
Dec 23, 2015 09:43 AM
NotSoSporty98
Nov 27, 2015 03:04 PM
bb65f1004x4
Jul 17, 2015 08:18 AM
raidscsi
Aug 25, 2014 12:17 PM
