tire question?
Old Apr 10, 2006 | 03:29 PM
DCH614's Avatar
DCH614
tire question?
I have a 00 f250 SD, 2wd, is there a big diff, between putting load D instead of load E on this truck I don't haul anything heavy, mostly drive around town.
Old Apr 10, 2006 | 04:18 PM
CEP's Avatar
CEP
It's a load issue, if you're not carring the weight, "D"'s will do just fine. Might even soften-up your ride.
Old Apr 11, 2006 | 12:31 AM
jtharvey's Avatar
jtharvey
You should have no problems at all. I've used the D rating for my last 2 sets of tires, and I do haul a lot of stuff around & on the highway. I've never had a problem. Just be sure to use a quality brand tire.
Old Apr 11, 2006 | 01:40 AM
cangim's Avatar
cangim
I run Ds as well, main thing to look for is actual weight rating of each tire. I haven't had any problems with mine, and as state prior, may even help the ride out some. Some like a truck, I like a truck than will ride like a caddy, and perform the duties of a truck.
Old Apr 11, 2006 | 07:11 PM
foxracer800's Avatar
foxracer800
just put pro comp all terrains on today that are load range D and love them, but have only logged 60 miles on them.
