rubing compond
My question is what is the best steps in doing this? I know it is going to be a tough job so why not do it right.I do have a buffer (DA)to use,But had better luck by hand.
Thanks Don
Do it all by hand. I'd be afraid of damaging what paint you have left with a buffer.
Good luck and let us know how things turn out.
1. Clean
2. Polish
3. Wax
You need to get that oxidation off before you polish. I like TR3, but you can use a similar product. When you clean the paint, you want to use the least abrasive cleaner as necessary. It doesn't take long to get down to metal with a heavy abrasive. As mentioned above, going by hand is a safer bet.
After the oxidation is gone, you can come back with a polish and finish with wax. I like carnuaba wax. Polimers can leave a coating that you can't get through if you ever need to work on the paint. Carnuaba wax will strip off as needed. Depending on your environmnet, I'd wax 2-4 times per year. You should be safe to do that with the buffer.
It's a lot of work, but well worth the results. I'm buying a 1979 F-250 that needs this same treatment. I can't wait to see the finished product. Don't forget to take before, during and after photos so that you can memorialize your work.
Good luck!
-Honorable
