Any of you guy's have any rough idle issues on a 97? I've changed my oil around 3,500 mi since new, grease joints @ 1500 mi intervals. The truck now has 271,000 mi on it and once you're rolling it runs great. Whether it's cold or warm weather it still idles rough. I haven't changed injectors yet. Any thoughts would be greatly appreciated.
I have a 97 that idles a little rough. It kind of shudders every 5 seconds or so. Power is also in question. I am waiting until I know it is not the fault or the winter blend fuel. There have been a lot of rough idle threads lately. Do a search and you will see them all. Are you using diesel kleen or the like?
i'd maybe have a cylinder contribution test done. might not be hittin on all 8. you may wanna get your injectors reworked back to stock or even modded a little.
Can you please explain the relationship between rough idle and transmission type?
I am curious about that.
I was having trouble with my 1-ton having a "rough idle." I couldn't figure it out. Took it to the dealership and was told my flywheel was coming apart. Only a problem for the manual tranny. Not a cheap problem either.
iwas haveing same problem with my 97, aoto trn, 99000 miles. tryed every thing got to reading the fourms and cleaned my fuel regulator screen, it was totaly pluged off.
What a diffrentences, it runs like it was new now. the rough idle is gone, I have not had a lot of problems with this truck I bought it neww in 97. Love my ford diesel.
hope this helps cem
