Clutch ?
Old Apr 10, 2006 | 08:59 AM
d_stange's Avatar
d_stange
Clutch ?
Have a 1988 F150 with a 302 and a M5OD. I was wondering what does the clutch do when the slave cylinder is going bad. I put a new clutch in it 2 years ago because a mouse decided to build his nest in there . Anyway, lately it seems like the clutch is getting spongy. Someone said the slave could be getting bad. Is this true. I hope it don't need another new clutch. it's only got probaly 10,000 miles on the clutch. I have done some pulling with it but not all the time. Any help would be greatly appreiciated.
Old Apr 10, 2006 | 09:28 AM
FordBoy68's Avatar
FordBoy68
Have you tried to bleed the clutch or check the reservor to see if it is low?
Old Apr 11, 2006 | 11:13 AM
d_stange's Avatar
d_stange
No i haven't checked. How do you bleed the clutch. How would it have gotten air in it?
Old Apr 11, 2006 | 01:00 PM
FordBoy68's Avatar
FordBoy68
I would check the resevor to see if it is low first......... When I changed my clutch it some how got low so I added some fluid to it and it helped.
Old Apr 11, 2006 | 01:22 PM
andym's Avatar
andym
There's a bleed valve on the driver's side of the tranny. Fill it up and bleed it. Your slave may be leaking and that's where the air is coming from. That's why I always change the slave cylinder when I do a clutch on a 5 speed.
Old Apr 11, 2006 | 02:14 PM
d_stange's Avatar
d_stange
How hard is it to change the slave cylinder?
Old Apr 11, 2006 | 02:20 PM
andym's Avatar
andym
It's easy. All you have to do is pull the tranny back far enough to get in there. There are two bolts holding it to the tranny, and there's a white plastic collar that you have to slide out to get the hydraulic line off.
