Headlight relay question
Old Apr 13, 2006 | 02:35 PM
squeals99's Avatar
squeals99
so do i have the wrong relays if i only have 85, 86, 87, and 30?
Old Apr 13, 2006 | 03:14 PM
Bdox's Avatar
Bdox
If they are rated at 20 amps or more they will be fine. Just determine which are the contacts, for the power to go through to the lights from the battery. The other two will be the coil, one side gets the signal from the switch and the other side goes to ground.
Old Apr 13, 2006 | 05:19 PM
pmleow's Avatar
pmleow
What amperage of a fuse would you recommend? 15A? Or I suppose I could just look in the fuse box and see what is already being used for my headlights.
Old Apr 13, 2006 | 07:26 PM
Bdox's Avatar
Bdox
Fifteen amps is fine.
Volts X amps = Watts
Take the wattage of the headlamps (I'll use 55watts as an example.)
Divide the headlight wattage by the volts. 12v
55w divided by 12v equals 4.6 amps. Times two bulbs is just under 10 amps.
The filiments draw more when cold, but that is only for an instant but it has to be allowed for. So yes, a fifteen amp fuse is good.
Old Apr 13, 2006 | 08:40 PM
soccerlawn's Avatar
soccerlawn
So do I have to run the 12 guage wire from battery to just one relay or both?
Old Apr 13, 2006 | 09:54 PM
Bdox's Avatar
Bdox
One wire is fine. Just a jumper from one relay to the next. Only one works at a given time.
Country_boy_2007
Feb 20, 2014 12:20 AM
59Terry
Modular V10 (6.8l)
May 28, 2013 07:40 AM
hairyboxnoogle
Apr 14, 2012 03:58 PM
Festus Hagen
Aug 2, 2010 12:56 AM
Danny_Ocean
Apr 1, 2006 10:05 AM
